front strut replacement on 96 accord
Old Oct 15, 2018 | 01:40 AM
sasha's Avatar
Default front strut replacement on 96 accord
my 1996 accord 4cyl has 200k and the left front strut is blown. is there any need to replace the coil springs at this age/ mileage with the struts?
i have found autozone duralast loaded struts for $80 a piece. is this a good or bad choice for this car?
Old Oct 15, 2018 | 08:48 AM
I don't know firsthand how good those particular units are.
The advantage of loaded struts is you don't have to deal with compressing the springs. Much easier installation and sometimes it just works out cheaper as well. Being 22 years old, potentially the springs are also 22 years old, and I'd worry about corrosion. But I'm in the rust belt where they use a lot of salt on the roads in winter...
Old Oct 15, 2018 | 11:57 AM
Seanjordan20's Avatar
It's best to replace the whole thing. For $80 I would order online and get the set for $20 more if you can wait until Saturday to install.
AM-Autoparts (10 year warranty)
Rock Auto
Old Oct 17, 2018 | 09:32 AM
sasha's Avatar
thanks for the replies. i'm still looking but will most likely go with loaded struts. i cannot do the work myself and wasn't sure how much life is left in the springs.
Old Oct 17, 2018 | 11:21 AM
Some shops won't do the work if you bring in the parts. Some will, but don't warranty the work. It's worth a phone call to get that answered.
At 200k-miles and 22 years old, EVERYTHING is fair game to look carefully for wear & corrosion. Springs don't wear out in the normal way like tires & brakes, but once corrosion gets under the paint on the springs, you gotta look at this as a good opportunity to avoid duplicating the same work later.
dcpappas1965
Feb 15, 2018 07:06 AM
drifterz73
Mar 9, 2015 08:29 AM
mpanelli
Jan 11, 2011 11:18 AM
jerrym
Aug 21, 2008 10:07 PM
mamtsberg
Jun 13, 2007 11:48 AM
