front tire driver side hops
it happens everytime i start the accord and put it on gear to go and then on my driver side tire it starts to hop,like it vibrates,but when the accord has been running and hot there is no hopping what so ever,it also happens when making a left turn only. i replaced my cv boot both inner and outer because my outer needed to be replaced ,still has that problem.is it aligment or could it be my cv shaft?
well since there was no shout out on this thread of mine since i posted it,i will give an update to this problem of mine.since i replaced the cv boot on that shaft andbefore greasing it up i had clean the outer shaft with all the old grease and who knows whats in there since my boot was torn i don't know how long,packed all the new grease in,installed it,left it parked for a couple of days,took it for a ride that one day,parked it for a few day again,this time for a real test drive,started the accord took off real hard and BANG! no more hop no more vibe!!!since this,it has been alright so far so like my problem happen to be my shaft the outer boot was torn and all the grease was exposed and more than likely all gone..
So it was a bad CV Joint... or the boot?
seems like if a boot is torn, you'd have to clean it real well, or replace the joint as well, right?
I've only replaced one CV joint and it was on an older VWRabbit, so I dunno, just curious.
well it was my boot that was all torn,so like i had to clean it out real good.i had used a pressure washer to clean out my cv shaft,i was lucky i guess that i did not have to replace the whole shaft.it works fine now.
Hmm.. I'm not sure how well that'd work personally...
From what I understand, just a little bit of dirt can really eat up a CV joint...
Just be sure you cleaned the hell out of it! It might hold you over for a while though.. not sure...
can anyone speak to that?
jza240sx
Apr 30, 2013 04:14 PM
iimzii85
Nov 1, 2010 01:16 PM
jblackwe1969
DIY Answers.
Jul 8, 2010 12:04 PM
19accord92
Apr 10, 2006 03:52 PM
