On installing strut tower braces
Old Jun 18, 2008 | 04:01 PM
peter4jc's Avatar
Default RE: On installing strut tower braces
ORIGINAL: winndogg34 i was told to go for rear sways before i do front sways is this how i should attack it?
also if i get rear sways, what exactly do i need for the install.... i see links, bushings, bars, etc... gets confusing...
I beefed up my rear sway bar by going w/ an '04 TL, from an Acura dealer, and left the front alone. Very neutral handling.
For the rear, you'll need brackets and bushings according to the diameter of the sway bar. Chances are, if you buy the bar from a dealer they'll have the bushing/brackets too. If you live where rust happens, you may as well save yourself some grief and spend the money for new end links right away. They're almost impossible to get off, due to the allen-wrench bolts. When I saw that I was getting nowhere, I got out my sawzall w/ a metal-cutting blade and sawed through the end link threads. That's on a '98, but I'd guess yours are similar. Sorry I can't help you with choosing a sway bar. My stock sway bar is supposedly a 17mm diameter, and replaced it w/ a 22mm, so I'd suggest something in that range- 22mm- 24mm.
Old Jun 18, 2008 | 04:12 PM
falkore24's Avatar
I believe that the Progress bar is the largest at 27mm, but I could be wrong. After all, I don't even own a Honda!!!
Pattywagon
May 15, 2012 10:10 AM
jjmaccord
Sep 1, 2011 11:12 AM
dacpt@comcast.net
Nov 19, 2007 03:48 PM
dacpt@comcast.net
Nov 19, 2007 10:19 AM
dinzer
Sep 6, 2005 01:04 AM
