Lower Control Arm - What Else?
Old May 28, 2014 | 09:37 PM
Beltwear's Avatar
Default Lower Control Arm - What Else?
2005 Accord.
Plan to replace the LCAs due to the compliance bushing. Seem's easier to replace the entire thing than take it out, get bushings pressed in, then install.
Is there anything else I should do? I am thinking to replace the Ball Joint Boot. Is this difficult on the car (installing the clip)? Can I replace the Ball Joint while on the car (will the Ball Joint C-Clamp Tool fit?).
Old May 29, 2014 | 05:46 PM
Well, the book doesn't say that the knuckle has to come off to change the lower ball joint - so I'd have to say it can be pressed out/in without removing the knuckle
Old May 29, 2014 | 06:10 PM
Beltwear's Avatar
Thanks. I am just wondering if the axle will be in the way. I've seen some posts with pictures of an axle clip being in the way (with the axle off).
I'll probably just do a "pre-inspection" before I order parts.
Am4wag
Nov 12, 2008 09:51 AM
mtnbay
Jul 20, 2008 03:22 AM
oma93
Feb 13, 2008 09:19 PM
Steve93
Oct 19, 2007 05:02 AM
RoKnAzn
May 21, 2007 06:29 PM
