lowering a 93
Old Apr 10, 2007 | 01:39 PM
accord93's Avatar
Default lowering a 93
anyone know if lowering a 93 ex coupe would be a good idea? and how much work would be needed to do this? i have found cheap lowering springs but the problem for me would be compressing and putting them on. any suggestions? thanks
Old Apr 10, 2007 | 02:11 PM
bssmagik83's Avatar
Almost A Senior Member
Default RE: lowering a 93
I did my lowering and it wasnt that bad. You canrenta spring compressor from most chain auto part stores. The only problem I had was that the bolts used to compress the springs were a little long and ran up into the fender well. I just cut them down about 3 inches and kept them.. You'll find it alot easier (less forearm work and time)if you can use an impact gun. lookin the DIY section and find out how to take it all apart and put it back together..depending on how low you go you might want to consider struts as well...
Good Luck
Old Apr 18, 2007 | 09:43 PM
thunder_x's Avatar
there's this shop in my area that installs both springs and shocks for 100 and the camberkit is 60
the name of the shop is overdrive performance in southern california
JFK
Aug 9, 2005 11:23 AM
goldenchild1982
Aug 5, 2005 04:05 PM
Shocker
May 20, 2005 01:59 AM
Opie
Mar 30, 2005 06:54 PM
Feb 13, 2005 09:16 PM
