Need help ??
Old Mar 30, 2007 | 10:30 PM
Chaqui04's Avatar
Default Need help ??
I own a 04 accord coupe v6 wich i've install a set of eibach pro kit springs . Now i need to do an alignment but what do i need to buy for the front and the rear.
Old Mar 30, 2007 | 10:38 PM
poser_pilot6
Default RE: Need help ??
Im not really sure I understand your question. However, if the springs lower your car by more than an inch or so, you will need a camber kit, likely front and rear.
Old Mar 30, 2007 | 10:49 PM
Chaqui04's Avatar
Right but i've beenseen that for the front suspension they sell an adjustable lower ball joint or a bolt with a nut now should i just buy the adjustable lower ball joint and the adjustable rear arms ?
Old Mar 30, 2007 | 11:27 PM
ORIGINAL: Chaqui04
Your est bet is to let your alignmrnt specialists tell you what parts you need to buy..make sure they understand about lowered suspensions or don't let them touch your ride...
Camber kits a must on your car:
WheelBrokerAng [sm=bling.gif]
Old Mar 31, 2007 | 01:54 AM
03Sleeper's Avatar
You might as well get new shocks/struts to compensate.
99accordf23a5
May 6, 2014 12:51 AM
brandyn
Nov 26, 2013 05:31 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
ryan ortego
May 19, 2005 06:06 PM
