need help with coilover kit
Old Mar 7, 2007 | 10:53 PM
hawaiian5's Avatar
Default need help with coilover kit
i have the NEX suspension coilover kit. my question is!, how do i make sure that all 4 wheels are lowered to the same height? how do all you guys do it? do i have to measure it some way?, or do i need a special tool? i just dont want my car do be uneven. i wanna make sure that they all are at the same height, and not off a little. thx and aloha
[/align]
Old Mar 9, 2007 | 12:13 AM
j_man_honda's Avatar
Default RE: need help with coilover kit
I just installed K Sport Coilovers on my accord. The process of getting it the right height was relatively easy. Before you install coilovers, measure the distance from fenderwell to top of eachtirewhile thecaris offthe ground. After you install the coilovers, measure it again and adjust coilovers up or down depending on how much you want to lower it. After you install coilovers, drive the car around for about 20 minutes and let the coils settle down. Measure all of the spaces and see if they match. Adjust accordingly.
Old Mar 18, 2007 | 02:42 AM
porter351's Avatar
the true right way is to put it on wheel scales. the easy way is to measure from the center of the wheel to the edge of the fender. make sure ur even on all sides and u should be straight.
Thumper
Sep 11, 2011 05:37 PM
martell92
Feb 9, 2011 10:47 PM
JDM_martinez_98
Feb 7, 2010 08:02 PM
6SPV6
Aug 20, 2008 03:22 PM
tsblckcord
Apr 25, 2006 12:58 PM
