Need help on Lowering
Old Jan 7, 2007 | 04:18 PM
ohsmustangs09's Avatar
Default Need help on Lowering
i have no clue.. what do i need to lower from stock height down 2.0 in. ?!?!?! and how much about will that cost ?
Old Jan 9, 2007 | 09:53 PM
sir_nasty's Avatar
Default RE: Need help on Lowering
Depends on how you want to do it.... the ideal way is to get aftermarket springs/shocks/coilovers and that setup can run you anywhere from $300.00ish on up.... I personally got an H&R Cup Kit for about $650.00 that included the springs/shocks/struts and worked great....
Old Feb 3, 2007 | 02:28 AM
vtecHef's Avatar
Where can u take that kit you were talking about.. to get installed.. i dont have acess to the right tools to do it myslef ?
Old Feb 22, 2007 | 03:05 PM
samtheturtle
Well, you can find cheap kits on eBay, just look around first and research which one you want before buying. As for installing them yourself, you can probably do everything with hand tools except you'll need a spring compressor to install the springs. You might be able to rent this from a local store for about $15. Otherwise, just go somewhere and get them installed. My total install job cost about $190 at a local place.
Old Feb 23, 2007 | 07:36 PM
richomundo's Avatar
I don't want to hijack the thread, but this isn't worth posting a new topic, and it is relevant.
How necessary are camber kits when lowering a vehicle with a kit of shocks and coilovers?
Old Mar 2, 2007 | 11:19 PM
DKYamada's Avatar
depends on how low you go
I lowered my accord about 3 inches, and tire wear (negative camber?)was noticeable after 3 months.
Unless you want to go through tires every 6 - 8 months, i would recommend camberkits
Old Mar 3, 2007 | 05:51 AM
traceyouinchalk's Avatar
Mines too low that it scrapes the exhaust on speedbumps and driveways....[8D]
SlammedNiss
Apr 8, 2014 06:26 PM
firedog
Dec 13, 2013 11:31 PM
onthedrums
Apr 24, 2013 10:31 PM
Thumper
Sep 30, 2011 05:36 AM
HondaAccordEX94
Jan 20, 2010 09:16 AM
