New Springs
Old Mar 29, 2007 | 11:23 PM
03Sleeper's Avatar
Default New Springs
Do I need to replace my shocks as well?
I got the Neuspeed 55.20.52.
Old Mar 29, 2007 | 11:42 PM
poser_pilot6
Default RE: New Springs
Going that much lower than stock, you probably want to install new struts. You can drive on your stockers for a while, but they will blow eventually. Its up to you whether you do it now or later.
Old Mar 29, 2007 | 11:52 PM
03Sleeper's Avatar
Hmmm...Megan Racing has 2" drops in the front and rear...new shocks?
And struts = shocks?
Shocks: http://cgi.ebay.com/ebaymotors/TOKIC...QQcmdZViewItem
Springs:
http://cgi.ebay.com/ebaymotors/Lower...QQcmdZViewItem
Old Mar 29, 2007 | 11:58 PM
poser_pilot6
Well, yeah, basically struts and shocks are the same thing, but a little different. My car has struts. Yours may have shocks, Im not sure. But anyhow, you are going to need new shocks/struts for a drop of more than an inch, and soon. Even just lowering it an inch will wear them out prematurely. But two inches is even worse.
Old Mar 30, 2007 | 12:02 AM
03Sleeper's Avatar
You think Honda changed its suspension into shocks by 7th gen?
Yeahh...I was reading and 1.75" - 2" drop is considered "extreme", 1" - 1.5" is considered "moderate" and 0.5" to .75" is considered minimal
The sad thing is....even if I drop it 2", the wheel gap is still pretty noticeable. I want to drop it so you can only fit 2-3 fingers in. Why did they make the wheel gap so large??
Old Mar 30, 2007 | 12:51 AM
03Sleeper's Avatar
I'm also assuming that the springs are on the outside,while the shock in inside the spring.
Old Mar 30, 2007 | 12:59 AM
HuYnHness's Avatar
yeah as far as i know you assume correctly the shocks run through the spring and the spring sits inside the plates on the shocks
Old Mar 30, 2007 | 01:02 AM
03Sleeper's Avatar
Sweet.
I look how the colors clash...Orange Springs with Blue Shocks....well at least the sleeve will cover the blue.
Old Mar 30, 2007 | 01:07 AM
ORIGINAL: poser_pilot6
Plus you more than likely will need to get yourself a Camber Kit ...
Old Mar 30, 2007 | 01:15 AM
03Sleeper's Avatar
awwww darnit...this is going to be expensive.
Neuspeed Racing Springs 55.20.52: $119.99 (Including S&H)
Tokico HP Shocks/Struts: $284 (Including S&H)
Ingalls Front/Rear Camber Set: $280.70 (Including S&H)
Total: $684.69
Is the Camber Kit absolutely necessary? I know driving with stock would cause alignment issues...
