-   Suspension (https://www.hondaaccordforum.com/forum/suspension-14/)
-   -   Polyurethane bushing kit question??? (https://www.hondaaccordforum.com/forum/suspension-14/polyurethane-bushing-kit-question-12573/)
rtmobile96 Sep 17, 2007 12:20 AM
So all my factory rubber bushings are shot. I'm thinking of putting a poly. kit in. Who sells the best all around kit for the right price? The only brands I know about are Energy Suspension and Prothane. Any tips or feedback would be great. Thanks.
s20700134 Sep 17, 2007 02:24 AM
RE: Polyurethane bushing kit question???
My experience with TASauto has always been good.
BlkCurrantKord Sep 17, 2007 04:20 AM
summit racing sells them as well
y9pema Sep 17, 2007 09:37 AM
wherever you get them from do it! i just had mine done. Unbelievable, you will notice the difference immediately.
sir_nasty Sep 17, 2007 10:47 AM
Energy suspension would be me recommendation. Check out TASAuto parts as mentioned.
Velocifero Sep 17, 2007 04:44 PM
ORIGINAL: sir_nasty
^^word, i got mine off this site here. another friend who has them recommended that site to me. came out to like $108 shipped for the master kit. i dunno about TAS, but on here you have the option of getting the black versions at no extra charge. the black ones are graphite impregnated for self-lubrication. i would still grease most of them, but it will keep the squeaking away much longer than normal. i just got my kit 2 days ago from them. ive only installed the sway bar end links so far (theyre the easiest). i cant wait to change the rest.
rtmobile96 Sep 18, 2007 03:37 AM
Good deal, thanks for all the feedback. The site Velocifero gave me has them at a damn good price. I thought I was ganna pay closer to $200 for a set. Now as far as install goes, is this a job I can do in the garage with normal tools, or do some of them need to be pressed out and back in by a shop? And I've never done any kind of bushings before, is there instructions?
sir_nasty Sep 18, 2007 01:35 PM
In the kits I've seen (which wasn't for an accord...) SOME of the old bushings had to be pushed out/removed but the new ones were split so that they went back in without a press. As for difficulty most of them are fairly easy, a few of them (on the shocks and such) may require a bit more work
falkore24 Sep 18, 2007 04:02 PM
A friend of mine just did bushings on an EP3 Civic SI. I know it's a much different car, but all of his bushings were torched out, casings carefully split and removed and most of the bushings were pressed in with a hydraulic press. I think that there was 1 set of bushings that were split. If you don't know what you are doing, this isn't a novice level DIY.
rtmobile96 Sep 19, 2007 03:42 AM
I wouldn't say I'm a novice level, but doing bushings would be something new. I can use either the manual or hydrolic press at my work if I need it. As far as instructions go, I more or less am hopeing it will tell me which bushing goes where. If I don't feel comfortable doing it, I won't. I've already learned that leason. Thanks for the info., hopefully I'll be able to order the kit sometime soon.
