question about lowering and tire size
Old Apr 23, 2008 | 05:36 PM
falkore24's Avatar
Default RE: question about lowering and tire size
the inner lip of the rim will ride 9mm tighter on the inside. At max turn, you need to see if it will rub on anything. Also, the outter surface when going straight will be 29mm further out than the stock wheels .... see if that's ok too.
There are no hard fast rules for combining lowering and upsizing rims. There are just too many variables. In general, I think those rims will fit fine, but at full turn, they might rub a little, though to say for sure (I don't think so). If that is the case, you lose a couple of degrees from your tightest turn that you can make .... not a big deal for most people.
Old Apr 23, 2008 | 05:42 PM
kahnvict850's Avatar
so basically might as well just do the 1.5 in drop, keep the 205/40/zr17 and just becareful or go 215/50/zr17 and maybe lose a little turning radius, not to bad i guess, glad i didn't go 18's like i was thinking about, then my choices would be very little to none. thanks guys
Old Apr 23, 2008 | 05:48 PM
finch13's Avatar
You'll have to even more careful pulling into parking spots. For some reason I always scraped the tow hook and not the lip... odd. Anyways, it was half worn down when I totaled it.
Also, you should upload some pics to your galley. I don't think I've ever seen a 5th gen in such an awesome blue.
Old Apr 23, 2008 | 06:07 PM
ok i made a gallery, my digital camera is on the fritz, but i had these already on my pc, keep in mind the car is dirty and i've done some more things to it since then, but i got some pics up, will put better ones once i either get a new camera or fix mine !
Old Apr 24, 2008 | 09:09 AM
falkore24's Avatar
For the tire size change, use the miata tool. It will tell you how the overall height compares between the 2 tires and also with the stock setup. It also tells you how much off your speedo is. A 50 sidewall will give a descent amount of cushion over the 40's.
Old May 1, 2008 | 08:23 AM
louofm1's Avatar
my 95 has a 1 1/2" drop. Do a search on yahoo on "tire size calculator". Discount tire has one.
Here are pics of my car. It's not bad fora 13 year old car:
https://www.hondaaccordforum.com/m_104675/tm.htm
Old May 4, 2008 | 06:46 PM
  #17
hey you are rolling on the same rims as me louofm, and the 1.5 drop is about where i wanna go, so what size rubber are you running?
Old May 4, 2008 | 08:47 PM
  #18
finch13's Avatar
For 17x7 wheels you'll want to go 205/40/R17 or 215/40R17, the first is a little smaller than stock and the second is a little larger than stock, plus they are pretty common sizes. I had the Pro-Kits too and they advertise 1.2 inch drops, but they settle to about 1.4-5.
miata.net has a nice tire calc too.
06AccordVp
Apr 28, 2010 01:25 PM
drive2getthere
Feb 13, 2009 05:36 AM
jamoke59
Sep 15, 2007 06:02 PM
izncate
Jun 11, 2007 04:59 PM
larsonk
Dec 15, 2005 04:52 AM
