quick question bout springs
Old Jun 2, 2008 | 02:41 AM
umarJ30
Default quick question bout springs
so i got a 2006 2dr accord 6speed and im tryin to lower itboth for looks and handling. but im not tryin to spend alot of money, so i was thinking about jus getting some springs like the eibach sportlines that drop it 2 at the front and 1.4 in the back. but a freind told me that by getting just springs i would be hurting my car and that i have to get shocks, struts and everything else. and while im on the topic, what is the difference between springs and coilovers?
thanks
Old Jun 2, 2008 | 09:02 AM
finch13's Avatar
Default RE: quick question bout springs
Anything over 1" is going to need new shocks/struts and a camber kit for a decent ride. Use the search feature in my signature to find more info.
Old Jun 2, 2008 | 08:22 PM
j_man_honda's Avatar
Coilovers are a full shock/spring already assembled and just bolts right in place of factory shocks/springs. Coilovers allow you to adjust the height to your liking. As said above, use the search feature
Old Jun 2, 2008 | 10:34 PM
tnguyen600's Avatar
A nice coilover kit will also allow you to adjust the damper, how hard or soft you ride. and if you really want to get fancy, you can get the motors to adjust the damper from inside your car, ie Tein's EDFC
Old Jun 25, 2008 | 03:41 AM
ziwang55's Avatar
cant u do the the same with eibach sportsline with koni struts/shocks?
Old Jun 25, 2008 | 08:24 AM
03Sleeper's Avatar
Yes...but the advantage of coilovers is that they are adjustable. You can adjust the ride height and camber wear whereas the ride height is limited to your spring and you'll probably have to get a camber kit to go along w/ your shock/spring setup. that being said, coilovers are notoriously expensive.
Old Jun 25, 2008 | 09:46 AM
finch13's Avatar
Koni's have adjustable spring perches FTW lol.
Old Jun 25, 2008 | 01:51 PM
03Sleeper's Avatar
I thought only Koni Yellows have that feature....or are all Konis Yellow..... *crap*
Some KYBs are adjustable as well.
Old Jun 25, 2008 | 03:40 PM
ziwang55's Avatar
but does it still work good as a coilover tho?
Old Jun 25, 2008 | 03:46 PM
finch13's Avatar
Whatever damper is with the coilover is decided by the manufacturer. Springs and dampers can be mixed and matched, along with sleeve-overs. Think of coilovers as one unit.
Sleeper, yes the yellows have adjustable perches, and maybe a few other models too... that's different from adjustable damping though.
With my springs, dampers and camber kits, I could have bought a VERY nice set of coilovers for the same price I will end up paying.
