Shocks ?????
Old Apr 1, 2007 | 01:13 AM
Chaqui04's Avatar
Default Shocks ?????
I have a 04 accord coupe v6 with eibach pro kit springs should i also repalce the shocks and if so what brand of shocks are good for my setup?
Old Apr 1, 2007 | 12:06 PM
BATerrell's Avatar
Default RE: Shocks ?????
You'll be fine w/ the Pro-Kit and stockers. But, if you want to do the strut/shock thing, I had nothing to complain about with the Pro-Kit/ Tokico Blue's on my 98 Ek hatch. Rode better than stock to me.
Good Luck
Beau
Old Apr 1, 2007 | 01:56 PM
Shadow1992's Avatar
If you got the pro kit to lower the ride a bit, then you will want to replace the shocks. Stock shocks will work for a bit, but they will eventually blow out under those conditions.
Old Apr 1, 2007 | 02:17 PM
03Sleeper's Avatar
Even for a drop of less than an inch?
Old Apr 1, 2007 | 04:29 PM
Chaqui04's Avatar
I've notice that my car sits a little bit higher in the front than the rear will after market shocks even the car? ( I have eibach pro kit springs ).
Old Apr 6, 2007 | 02:34 AM
jchandler50
Chances are that the springs aren't sitting right in the front, which is causing the height difference. Try pulling them out, making sure they are positioned right top and bottom and put the back in. Drive around the block and see how it looks. Eventually you will need new shocks but if your trying to save some money in the mean time, try the above. It would be a good idea to start putting some cash away for some new shocks/struts though.
Old Apr 17, 2007 | 03:18 PM
theBrewMeister's Avatar
ORIGINAL: Chaqui04
The struts have nothing to do with ride height. Their main purpose is to counter balance the spring. BTW, KYB struts are around $55 a piece and work great with lowered applications.
Old Apr 17, 2007 | 09:37 PM
trukid21's Avatar
i agree,the prokit and kyb strut are good set up,that is what my set up is like and i love the look and ride.the slight gap on the front is not bad at all but i have 15's on.besides the kyb struts are cheaper but reliable set,so if your tight on money like me that would be a good buy.
ditbu13oi
May 8, 2007 05:56 AM
thunder_x
May 6, 2006 04:22 AM
putih
Sep 7, 2005 06:23 AM
vtec
Feb 13, 2005 08:56 PM
