shocks question
Old Jan 8, 2007 | 08:01 PM
ckebottle's Avatar
Default shocks question
I was thinking of buying some shocks from sparkplugs.com since they are having that sale. Would I need just the front and rear shocks or do I need the strut mounts and boots? And how hard is this of a diy? Looks like the fronts are pretty easy to access but how about rear? Remove a seat?
Thanks guys!
Old Jan 8, 2007 | 08:06 PM
sir_nasty's Avatar
Default RE: shocks question
Pretty easy job except for the springs. You'll need a spring compressor for that (you can rent them or take it all in and a shop will do it for fairly cheap) Rear's are pretty easy as well. The only "trouble spot" on this job is lining up the upper/lower mounts and springs etc. with the spring compressor..
Old Jan 8, 2007 | 08:22 PM
ckebottle's Avatar
Oh darn....I thought I cld just unbolt everything attached to the shock and pull it out and then drop the new one in and rebolt. Didn't realize I needed to compress the springs.
Old Jan 8, 2007 | 08:25 PM
sir_nasty's Avatar
Unfortunetly you will, however you can rent or buy the spring compressors for next to nothing or just remove all 4 of them and take them in with the new shocks/struts to a dealership and they'd probably do all 4 of them for $40-$80... I was in a bind once and paid to have the suspension swapped out (yes there is a difference between front and rear springs and H&R uses a great color scheme that I knew nothing about to designate that....) they charged me $250.00 in labor
AccordOwner1540
Oct 29, 2008 06:27 AM
ditbu13oi
May 8, 2007 05:56 AM
putih
Sep 7, 2005 06:23 AM
vtec
Feb 13, 2005 08:56 PM
