Should I buy/install lowering springs myself?
Old Jul 31, 2011 | 08:41 PM
1992hondawaglx's Avatar
Default Should I buy/install lowering springs myself?
Hi Guys,
I'm new to this forum as of tonight. I am looking to get my car back on the road soon. I need to replace rear bumper brackets. BUT I'm also looking to lower my car a little bit. I drive a 1992 Honda Accord Wagon LX. With 154k on it I'm loving it as a part time ride. Would installing springs that lower the car around 1 inch have any problems that would be caused by lowering it. (spring travel and body damage related)
Old Aug 1, 2011 | 08:19 AM
g22cd5's Avatar
Supper Moderator
if you install lowering springs you will need a set of struts that can handle the abuse of the springs. OEM struts blow out quick when lowered. My personally preference is coilovers. They can be more pricy but they are adjustable. B/c when you get lowering springs after they settle thats what your stuck with. With coilovers you have the option change your ride height around. But every time you change your ride high it's recommend to get a new alignment. You also want to look into camber kits for the front.
Old Aug 2, 2011 | 11:45 AM
Thanks for the tip!
Old Aug 2, 2011 | 01:13 PM
glperez's Avatar
i am thinking about doing the same, but heard coilovers bounce around to much. i was looking into some skunk2 lowering springs and shocks
Old Aug 2, 2011 | 05:12 PM
g22cd5's Avatar
Supper Moderator
coilovers don't bounce allot. You just feel the road a little bit more. But if you pair up coilovers with the right struts your fine. You also can buy FULL coilover kits (which I recommend) that have the coilovers built onto the strut. So you have a shock matched for the spring rate of the coilovers.
iskate604
Sep 8, 2013 07:29 AM
TheMysteriousYes
Nov 23, 2011 11:15 PM
paintballa408
May 5, 2011 04:25 PM
duvalla08
Sep 5, 2008 05:15 PM
