can i install my catback myself?
Old May 5, 2011 | 02:46 PM
paintballa408's Avatar
Default can i install my catback myself?
my cat makes a bad noise at a certain rpm and i wanted to know if i could change it on my own or does is have to be welded? i have a 95 accord 4 door dx
Old May 5, 2011 | 03:33 PM
are you looking to change to a "catback" exhaust or looking to change out the catalytic converter?
Also what is a bad noise? It could just be the heat shield rattling so I wouldnt go replacing a catalytic converter as they are pretty costly.
But to answer your question when it comes to replacing either one................it depends. Replacing either would be a pain without a lift but its not impossible. What might require a shop is getting them off as often the bolts are rusted on and cant be taken off by conventional means. You often need a torch to cut the bolts off.
Old May 5, 2011 | 04:18 PM
o ok got ya. i have a catalytic converter and i was told by a mechanic that it was the catalytic converter that was rattling making an errrr noise when i get to about 1700 rpms.
Old May 5, 2011 | 04:25 PM
Sounds like you'd better let a shop with a lift get at that for you...
JimTrail
Nov 19, 2016 06:39 PM
TheMysteriousYes
Nov 23, 2011 11:15 PM
1992hondawaglx
Aug 2, 2011 05:12 PM
EzraFitch1990
Mar 12, 2008 10:11 PM
pyaarawala
Jun 10, 2007 09:25 PM
