springs and shock installation... pointers ???
Old Sep 22, 2007 | 12:30 AM
MrGmo's Avatar
Default springs and shock installation... pointers ???
so i got my Tein springs today, gonna get the shocks tommorow, does anyone think i can do this install myself or do you guys recomend getting a pro to do it...
im pretty savy mechanically and ive done ton of work on a karmann ghia i used to have, shocks n the whole lead... does anyone know what tools i will need or what to watch out for???
any help is appreciated!!
Old Sep 22, 2007 | 01:09 AM
stevent's Avatar
Default RE: springs and shock installation... pointers ???
rent a spring compressor, it'll make things alot easier. Also,block out the whole day since you might mess up. Lat but not least, if your of legal age, beer, if not, root beer hahaha.
Old Sep 22, 2007 | 01:30 AM
MrGmo's Avatar
spring compressor... got it, and lol yea im over 21 and live in Los Angeles, so im of legal age... ill get a six pak.. dont want too much coz then ill prolly end up getting hurt or messin up the car lol... now that i think of it, ill drink AFTER im done and have gone for a test drive coz i always get the urge to test drive when i do a mod, lol...
i was planning on doing the front, and seeing how the car looks lowered only from the fron since i have the most inches in between the tire and fender, ill see if i can take pics for you all to see how it looks before and after....
Old Sep 22, 2007 | 07:35 AM
BlkCurrantKord's Avatar
Extended 6 point -17mm (1/2in), 14mm and 12mmsockets, 17mm wrench or socket and ratchet
Jack (maybe 2 - I think it helps to have 2)
Air gun
BFH - big ****ing hammer
Antiseize
PB Blaster or WD40
I just put new coilovers on my 98 coupe about a week ago, by myself in under 3hrs. Air gun or air tools are essential or at the minimum, a breaker bar. It'll be kinda tricky when you go to remove the spring/shock combo b/c its much longer compared to the new ones you'll be putting in so you kinda have to manuver it just right to get it out of the wheel well. For the rear, don't bother trying to remove the endlinks for the sway bar, just unbolt the brackets they're attatched to at the knuckle.
Old Sep 22, 2007 | 11:11 AM
sir_nasty's Avatar
Something to watch for is the alignment of the cap to the forks. Make certain that the top of your shock cap (the part that has the bolts that go through the upper strut tower) is aligned with the forks on the base in exactly the same fashion as it was when you took it out. One way to do this is when you pull the old one out lay it on a piece of cardboard or paper and trace around it, then lay the new one on the tracing and make sure that the bolts and bottom fork align the same way. If you have it wrong it will be a PITA to re-install.
Old Sep 22, 2007 | 03:17 PM
Sir Nasty has a very good pointer here on how to keep it working at the right level by traceing around it and then useing that as a kinda templatr..Very Good Nate Thanks for putting that in here .
conyoman
Jun 18, 2012 10:43 AM
Tomtn2008
Feb 21, 2008 04:15 PM
dacpt@comcast.net
Nov 19, 2007 03:48 PM
Staszek
Apr 17, 2006 02:42 PM
redmill
Sep 28, 2005 01:38 PM
