Suspension Mod
Old Dec 9, 2008 | 12:21 AM
finch13's Avatar
Default RE: Suspension Mod
Hmm... I'll have to consider that. My ride quality just isn't poor enough for me right now... but the handling is excellent!
Old Dec 9, 2008 | 07:40 AM
falkore24's Avatar
#1 cheap mod for performance and handling: Take all of the dead hookers out of your trunk!!!
jk, IMO, the best is the TL-S rear sway as mentioned. To really make that puppy handle, find my old setup. I hit 0.95g-s on 2 occasions and held 0.9g-s many times with street tires ...... Yoko dB S2's
Old Dec 9, 2008 | 08:11 AM
Zeal coilovers...............not the cheapest, but boy oh boy will you notice a difference.
Been a while since I mentioned them, so had to do it.
Some say they notice difference from strut bars, Its debatable.
I say go the sway bar route.
Old Dec 9, 2008 | 08:52 AM
falkore24's Avatar
I noticed the difference when I put on the front strut tower brace, but then again, I already had everything else.
Old Dec 9, 2008 | 08:42 PM
JohnL's Avatar
ORIGINAL: live2rice
It's not 'either / or'. They both do something worthwhile, but it isn't the same thing...
I certainly noticed a marked handling improvement with my front tower brace, and then again with my rear tower brace.
However, many tower braces (probably most) are just not RIGID enough to do their job properly, so as a result there are many people who felt little or no difference when they fitted their tower braces, and who then advise other people that they are useless.
This is not because tower braces inherantly don't work (they inherantly do), but like anything else, badly designed ones don't work as they should...
With many tower braces, what money has been invested in making them has mostly gone toward making them look pretty, so just because a brace may look good doesn't guarantee it will work...
Old Dec 9, 2008 | 08:45 PM
My suspension brace:
Stiffened it right up.
Old Dec 10, 2008 | 08:18 AM
  #17
falkore24's Avatar
ORIGINAL: JohnL
ORIGINAL: live2rice
Also, there are a ton of people that do not install the braces properly. It is just too easy to slap it on quickly since the bolts line up, but if you do not release the preload caused by the weight of the car, the brace will not perform properly. The axle that you are bracing must not have load on it when installing the bar!! ...... aka, lift the car off the ground.
Old Dec 10, 2008 | 08:32 PM
  #18
JohnL's Avatar
I've mounted my front tower brace both pre-loaded and un-pre-loaded, and while I can't say that it made no difference, if it did I couldn't feel it...
Old Dec 10, 2008 | 10:06 PM
  #19
ORIGINAL: Honda01Accord
What is the cheapest suspension mod i can get for my 01' Ex Coupe, that will actually make a diff??
How about a set of 4 coilovers for Under $105.00
shipped to you...Brand New...Pm Me for more information...
[IMG]local://upfiles/22/891BE65D61F74744AE15CB8DAB260371.jpg[/IMG]
jjhu00
May 27, 2007 11:56 PM
George Knighton
Jan 11, 2006 08:49 PM
zelseman
Jan 9, 2006 04:22 AM
DrumProdigy83
Apr 23, 2005 02:00 AM
