Vtec brakes on accord 1990
Old Sep 19, 2007 | 10:31 AM
accord1990
Default Vtec brakes on accord 1990
I have a 1990 accord 2.0 exi with drums and i wonder if i canreplace with2.2 vtec brakes ?
Old Sep 19, 2007 | 10:38 AM
falkore24's Avatar
Default RE: Vtec brakes on accord 1990
pls add "90 EXi 2/4 door AT/MT" to your signature
you mean rear disc brakes. VTEC and displacement have nothing to do with them. Search the DIY's and I'm pretty sure that you'll find an answer. Fix the sig and more people will post comments. Good luck!
Old Sep 19, 2007 | 10:44 AM
accord1990
yes rear disc brakes.
Old Sep 19, 2007 | 11:20 AM
falkore24's Avatar
Here you go! Thanks for the sig. Note that most people say that there is no improvement in braking by doing this ...... I guess there are more pad and rotor options for further improvements.
http://www.accordinglydone.com/forum...ead.php?t=2056
Old Sep 19, 2007 | 11:45 AM
accord1990
ok, i see, but you know if i can juse the 2.2 vtec brakes? not just convert to disc but upgrade it to 2.2 vtec brakes
Old Sep 19, 2007 | 11:55 AM
falkore24's Avatar
I don't know the rotor/pad surface sizes. I don't see why you couldn't get it to work if it mounts up the same way. If your intent is to improve stopping power, get front slotted rotors (good quality only) and some Hawk HPS or EBC Redstuff pads. If you still need more, do the rear conversion. Also remember that shocks and swaybars will make the system more effective by keeping the weight distributed properly and tires tighter to the road.
Old Sep 19, 2007 | 12:23 PM
accord1990
The 2.2vtec has 282 diamter in front and 260 rear, the same as 2.2 accord
Old Sep 19, 2007 | 01:27 PM
falkore24's Avatar
If the mounting holes are the same and there's nothing too close to cause a conflict, i don't see why you couldn't do this swap. Search to see if it's been done before you do it. I'm yet to see a DIY swap that hasn't been written up if it's possible .... and it's not like an 08 where there hasn't been time for tuners to play with the car. Post a DIY if you do it ..... include pics with notes for others to use.
Old Sep 19, 2007 | 05:36 PM
Shadow1992's Avatar
I'd like to know why you say you have a 2.0 engine in your 1990 accord. All Accords went up to 2.2 liter for the 1990-1993 model years
Old Sep 20, 2007 | 04:33 PM
accord1990
No, here in Norway thecame with 2.0i
