What moron designed the rotors behind the hub?
Old Jul 11, 2009 | 08:54 PM
twinster2's Avatar
Default What moron designed the rotors behind the hub?
Bought a 1996 Accord for my 16 year old son last month. It had noticable vibration on braking so I figured it was a simple rotor replacement that I have done on countless fords and dodges over the years. I get the wheel off and I find that the rotor is mounted behind the wheel hub. Was there a reason for Honda to do the dumb a$$ design, or did they just want people to pay for having it done at the dealer? Anyway, after renting a 36 mm sock for the hub nut and a slide hammer, I was able to get the hubs off and back on with new rotors in about four hours (first wheel took about 3 hours and the second one took less than an hour since I figured out how to do it). Anyway, this is the first Honda I ever owned and so far I'm not very impressed.
Old Jul 11, 2009 | 09:17 PM
Smile Hello New Member
Now that you got past that bend in the road, we hope you will be much happier...
Welcome to the forums New Member...
Old Jul 13, 2009 | 10:38 AM
Well, beginning in 1998 Honda switched over to a normal rotor setup just like all the others. I never really understood the motivation for the hub-over-rotor setup.
Old Jul 13, 2009 | 10:44 AM
00AccordLX5spd's Avatar
Registered User
Yeah the 1998 - 02 simply require a screwdriver to get the rotor off once you have everything else off. But you cannot remove the hub without a hydraulic press. So they traded one bonehead design for another. (I had to pay a shop for an hour's worth of labor to replace a $1.50 lug I sheared a while back because the hub has to come out to drive out the lugs - I was NOT happy.)
Old Jul 13, 2009 | 10:33 PM
okie-f22
is there a pic of what this looks like? the hub-over-rotor design? cuz im bout to buy a '95 and that sounds like a pain in the $$$
Old Jul 13, 2009 | 10:55 PM
All the 94-97 have it. You can buy rotor over hub conversions, or a hub extractor to make it easier.
Old Jul 14, 2009 | 07:42 AM
This shows the hub (#3) outside of the rotor (#7). The wheel bearing (#2) bolts to the steering knuckle.
Old Jul 14, 2009 | 11:43 PM
Thinkmoto's Avatar
My old 323GTX and my geo metro have this setup. yes it requires more work but its not a dumbass idea....at least not too me. Everything has its drawbacks deal with it.
Old Jul 15, 2009 | 07:03 AM
Smile
Jim , you always have the great diagrams ready to go...Very Good
When are we going to meet for a Subway Lunch?
Angelo
Old Jul 16, 2009 | 10:04 PM
twinster2's Avatar
"My old 323GTX and my geo metro have this setup. yes it requires more work but its not a dumbass idea....at least not too me. Everything has its drawbacks deal with it."
Well, if it was such a good idea, why did Honda start putting rotors on the outside starting in 98?
