03 tire recommendations
Old Jun 30, 2008 | 01:41 PM
dmoak's Avatar
Default 03 tire recommendations
I'm in need of a new set of tires for my '03 EX V6 sedan. I'm not as concerned about all-out performance as I am about wear, comfort and all-season capability. Does anyone have a good tire to recommend?
Thanks!
Old Jun 30, 2008 | 02:23 PM
falkore24's Avatar
Default RE: 03 tire recommendations
Yokohamas are awesome. You won't be disappointed with them. I had the dB S2's which got discontinued due to a design flaw, but they handled beautifully. hey were Ultra High Performance All Seasons on tirerack.com. For you, I'd look into their High Performance All Season Tire. The lower the performance rating, the better they are in snow, for the most part.
Old Jun 30, 2008 | 06:04 PM
03Sleeper's Avatar
Michelen MXV4 premier energy (aka stock tires for the 03)....they last hella long, good ride quality and comfort. drove 95k on them before they finally wore down.
Old Jul 15, 2008 | 10:51 AM
DANSCREW
Try general altimax HP's they have very high ratings check Tire rack for info on tire went with a 215/60/16 the car rides better it is only 1/2 inch bigger great tire check em out
Old Jul 15, 2008 | 10:59 AM
RTexasF's Avatar
Super Member
I replaced the HORRIBLE Michelin OEM tires with Yokohama Avid V4S @ 30,000 miles. I simply could not deal with them any longer. TheYoksare 70% quieter than the Mich's, the ride is SUBSTANTIALLY improved, they corner better, don't squeal, wet weather traction is better than the Michs ever thought about, and the wheel returns to center better from a turn. Wear is an unknown since I only have about 1200 miles on them. You could also look into the same tire in an H speed rating, they are a bit less expensive than the V but neither one is cheap. Can you tell I'm pleased?
gimme789
Dec 14, 2012 07:32 PM
MrLemonHead
Jun 22, 2008 10:34 PM
RedSkull
Jun 19, 2008 05:12 PM
Stoenr
Mar 29, 2008 09:23 PM
dinzer
Aug 7, 2005 03:26 AM
