19 inch rims
Old Mar 24, 2010 | 08:54 PM
LyricalLyricist's Avatar
Default 19 inch rims
Hey guys, I'm new to the site and i'm looking for some help. I'm about to buy rims for my 2009 honda accord coupe ex-l 4 cyl. I'm looking at 19s but not sure if chrome is a good idea. I like chrome, i want it to stand out, but I don't want to look stupid either.
I'm looking at Avarus AV4 in chrome and stainless. Here are pics of the two:
Personally I like chrome more but I don't want too much flash. I'm trying to give off the luxury coupe look and I think chrome does that more than the other version of the AV4. Which do you think I should get? My coupe is black, I don't have the chrome door handles, but I'm thinking of adding that, tinting the windows and adding HID lights.
Thanks guys.
Old Mar 25, 2010 | 12:41 AM
Also, forgot to mention, the wheel is 19 inch, the tires are 245/40-19 with an offset of +45. Is that enough offset for a honda accord coupe 2009?
Old Mar 25, 2010 | 01:45 AM
Your tires should be no bigger than 225/40/19"s The offset or ET 40 -45mm
Wheel #1 would be my choice between the 2 wheels..
Old Mar 25, 2010 | 08:57 AM
Briggz's Avatar
Almost A Senior Member
I agree with Ang. I like the first one better. I'm not a fan of chrome rims. I think they only belong on big showy SUVs, or Caddies... not on Accords.
Old Mar 25, 2010 | 10:08 AM
Stock is 225/50-17 for me. I fear 225/40-19 would be too low pro for the roads I have here(i'm in montreal). Do 245 fit at least? Before i go lower than 245 I kind of want to know what the limits are.
Also, anyone know the offset of stock 17s on the accord coupe 2009? The rims are 19X8.5 +45mm offset. Does that fit? I checked a website about tire size difference and it says if the stock offset is +55, then +45 on tires 245/40-19 may not fit under fender, is that true? I know you Ang suggested 225/40-19 and i'll consider for sure, just a little concerned in regards to potholes.
Old Mar 25, 2010 | 10:53 AM
Briggz's Avatar
The big first number (245 vs 225) has nothing to do with the profile of the tire. That is the width of the tire. The second number, in this case 40, is the profile spec.
Old Mar 25, 2010 | 11:22 AM
I was told the first number (225) was the width and the aspect ratio was the second number. So if you have 225-70, the sidewall would be larger than stock(225-50-17), increasing your tires diameter. Is this wrong or right? That's why im asking if 245-40 has clearance over 225-40.
Old Mar 25, 2010 | 11:29 AM
You're right.
245/40 has taller sidewalls then 225/40 (245 is also wider).
(I don't know if there's clearance problems with springs, control arms, or fenders.)
Old Mar 25, 2010 | 12:33 PM
Briggz's Avatar
Unhappy
Sorry... I gave bad info...
Here's a page that explains all the numbers pretty straight-forwardly.
http://www.generaltire.net/generator...dewall_en.html
Old Mar 25, 2010 | 12:41 PM
I suppose this is a better explanation of what I'm looking for:
Offset: +45mm
Backspacing: 6.53"
Bolt Pattern: 5-114
Rec. Tire Size: 245/40-19
Weight: 30.2lbs.
I'm planning to buy off tirerack and when I checked a site for tire sizes(here). I got a warning under 'fender' saying:
Package will stick out 20 mm (0.8'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Stock:225/50-17 (I was told +55) 17X7.5
Aftermarket: 245/40-19 +45 19X8.5
When i reduced wheel width or increased offset the 'problem' went away so i assumed they played a role. I'm no expert in wheel fitments whatsoever, that's why i'm asking you guys for help lol.
What do you think? 245/40-19 +45 fit properly?(this is very important, if it's a tiny-pothole-and-you're-done...that isn't properly to me.)
I live in montreal, we have quite a few potholes...I'm looking to make this a useable car while having some style, so if it's a close call, I won't bother with 19s.
