2000 Accord 15" to 16"
Will stock 16" aluminum rims from a 2002 accord fit my 2000 accord that currently has 15" steel rims? I'd like to go up one size using Honda rims. Also, will 16" rims from the next gen Accord (2003-) fit my 2000 coupe? Much thanks for any info.
The 16's from the '02 should fit without any issues. You'd need to research the 03 and up to be sure the lug pattern and offset is the same.
For 2003 and newer, ALL Accords use the same 5-bolt pattern as the 1998-2002 V-6 cars. So if YOUR 2000 is a 4-cyl, it would have a 4-bolt pattern.
Thank you
My stock 15" steelies are 5 lug, so I want to go up one size when I switch over to stock aluminum rims. Thanks to both of you for the responses. The only issue left for me is deciding whether to get stock 16" aluminum rims that came with my generation Accord V6 coupe or go with the next generation stock aluminum rims.
That choice is about LOOKS, because either one should fit. Or aftermarket wheels...?
