2000 Accord 15" to 16"
Old Oct 15, 2011 | 08:13 AM
rarev6lxcouple's Avatar
Smile 2000 Accord 15" to 16"
Will stock 16" aluminum rims from a 2002 accord fit my 2000 accord that currently has 15" steel rims? I'd like to go up one size using Honda rims. Also, will 16" rims from the next gen Accord (2003-) fit my 2000 coupe? Much thanks for any info.
Old Oct 15, 2011 | 08:39 AM
The 16's from the '02 should fit without any issues. You'd need to research the 03 and up to be sure the lug pattern and offset is the same.
Old Oct 15, 2011 | 10:00 AM
For 2003 and newer, ALL Accords use the same 5-bolt pattern as the 1998-2002 V-6 cars. So if YOUR 2000 is a 4-cyl, it would have a 4-bolt pattern.
Old Oct 15, 2011 | 03:05 PM
Default Thank you
My stock 15" steelies are 5 lug, so I want to go up one size when I switch over to stock aluminum rims. Thanks to both of you for the responses. The only issue left for me is deciding whether to get stock 16" aluminum rims that came with my generation Accord V6 coupe or go with the next generation stock aluminum rims.
Old Oct 16, 2011 | 02:24 PM
That choice is about LOOKS, because either one should fit. Or aftermarket wheels...?
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
Andrew James
Sep 3, 2010 03:30 PM
