4 Lug Accord rims? will Civic rims fit?
Old Sep 10, 2010 | 11:18 PM
Post It's 9/11/2010 Right As I Post This...
About time he did, wouldn't you say Jim!
It's Now 9/11/10 ...9 years later
Attached Thumbnails  4 Lug Accord rims?  will Civic rims fit?-911515c0ty1v3l__ss400_.jpg
Old Jul 18, 2011 | 09:38 PM
livinlifes2short's Avatar
Default please help asap thanks team
Ha hopefully some one sees this I have the same question found some aftermarket rims for real cheap guy had em on a 93 civic I have a 96 accord but the rims have 8 holes in them does this mean they will ffit please respond don't wanna loose a good deal thanks!
Old Jul 18, 2011 | 09:50 PM
Smile Here You Go Member..Info >>>>
The 1993 civic has a 4x100mm wheel , hub size is 56.1mm and the offset is 35-42mm.
The 1996 Accord of yours has a 4x114.3mm wheel, hubsize is 64.1 and the offset is 35-42mm
Dual drilled wheels would have fit all except for the wheel hub size..not good..
Sorry!
Old Jul 18, 2011 | 09:57 PM
Here is a picture of the rims please let be know its 1.5hr trip don't wanna waste it thanks
Old Jul 18, 2011 | 09:58 PM
dang so u are saying no go right.
Old Jul 18, 2011 | 10:05 PM
Also seeing that tthey are aftermarket how do we know the rim hub size? Completely new too me so sorry ffor my ignorance. But could the rim hub hole be bigger or is that not possible because they wouldnt work on the older civic thanks again!
Old Jul 19, 2011 | 02:25 AM
  #17
ronjr8102's Avatar
the hub size is probably bigger and just need to use hub-centric rings between the rims and rotor. U will need the guy to measure the hub size. If he can do a good job of measuring to within a 1/16th of an inch just multiply that by 25.4 and u will get the MM size. If bigger than ur car then buy. After measure urself and buy hub-centric rings. Someone may b able to say yes or no but I hav seen people run rims w/o rings I think it just puts stress on the studs but hav never seen any studs break cuz of that.
Old Jul 19, 2011 | 05:23 AM
  #18
OK sweet will have him measure I really hope they will work for 120bucks they are perfect.
Old Jul 19, 2011 | 06:18 AM
  #19
The guy is at work but he said the rims would not fit on a focus and from some research there jb is 63.9 so there is no way 64.1 would fit unless he has the rings on there. That sucks really good deal i hhave having 3 stock rims and on steelie not to mention my stock ththey only made for 1 year on the 4cyl I cant find one anywhere!
Old Jul 19, 2011 | 07:54 PM
  #20
OK so he measured them they came in at 2" 9/16 so i picked em up 114 bucks my question is they are so close to my hub size do they make the rings small enough to cover tthe difference?
