5 lug conversion
How difficult is it to do a 5 lug conversion on a 1999 Honda Accord Ex 4cyl and what would I need to do this? Any information would be helpful, thank you.
In the rear you should get away with just the 5-bolt hubs & corresponding brake rotors. Check a parts place to see whether the caliper has a different part #, but I think they are the same.
In the front, get hubs & rotors also, but removing the hub from the steering knuckle will probably destroy the wheel bearing. Check the brake caliper part #s also. The reason I say check the calipers is I think(?) the 5-lug brake rotors are the same diameter, but I'm not absolutely sure. |
Will do, thanks.
