Accord 2005 exl sedan rims
Hey guys, I have a sedan accord 2005 exl dark gray. I wanted to mod it. Starting off with rims but I have no idea what rim or rim color would look nice with dark gray. Any suggestions?
Asking questions like this is hard to get a good answer, because everyone has different opinions.
Start researching rims, and find what you like. |
Yeah, I know but I wanted to know other peoples opinion on it. I was thinking about black rims but idk what rims to get yet.
Take a look at www.tirerack.com & see what they have to fit your car. Even if you don't buy from them, it can get you started with what kind of LOOK you like.
Depends on alot. What type of driving you like to do, the weather you drive in, and comfort level ... I have the same car (I use for a commuter), but the thing R O L L S around the corners pretty badly. But I have stock 15" steelies.
I'd like to know what wheel size will fit? I know 5 x 114.3 ... but what OFFSET is acceptable? I have a chance to grab a set of nice looking 16's with a 60mm offset ... Seems to be a big offset? Will they stick out from my fender wells?? |
Big offset goes in the other direction. Larger offset puts the wheels more inboard, resulting in a narrower track.
If you get small offset, then the wheels are more outboard. Again, check out TireRack website. Offset should be listed in the specs for all the wheels that show up as fitting your car. I kinda remember 40-ish numbers but not real sure about that. |
You are going to want 17s or 18s for the car. And you can And 60 is a very high offset. You can easily go with something +35-40 and have it not stick out.
Hello Member
2 Attachment(s)
Originally Posted by Kevinlee1521
(Post 330989)
