Acura RL wheels?
Old Dec 27, 2006 | 04:24 PM
daytonphotog
Default Acura RL wheels?
I have a 2001 accord LX V6? I wanted to buy a set of 2006 Acura RL wheels with 245/50/17. I wanted to know if any one has done this or know if they with fit?
Old Dec 27, 2006 | 04:30 PM
sir_nasty's Avatar
Default RE: Acura RL wheels?
I'm not 100% sure on the size, you can use a tire size calculator (top post in wheels/tires section) and see what the speed/size difference is... the bolt pattern should be the same but I'd double check it to make sure... So: It should work but double check it for yourself online, www.1010tires.com has calculators and such...
Old Dec 27, 2006 | 08:56 PM
vintageant's Avatar
I'm pretty certain your bolt pattern is 5 x 114.3 and the Acura RL bolt pattern is 5 x 120, so doubt that they will fit.
Old Dec 27, 2006 | 09:06 PM
sir_nasty's Avatar
You got me curious... and vintageant is pretty much right (minus what I would assume is a small typo) but you have a 4 x 114.3 pattern and the RL is 5 x 120 so, no dice.... I was not aware that acura switched to a 5 lug rim...
Old Dec 28, 2006 | 08:37 PM
vintageant's Avatar
No, not a typo. My 2003 is 5 x 114.3, so I assumed 2001 was the same. I didn't realize that 2001's were 4 bolt. Apologies for misdirection!
This explains bolt patterns: http://www.rsracing.com/tech-wheel.html
Old Dec 28, 2006 | 08:45 PM
sir_nasty's Avatar
right on! I didn't know that... I love learning new stuff thanks for the followup and info vintageant
Old Dec 28, 2006 | 09:32 PM
daytonphotog
Thank you all for your help. I got so concerned with the tire size I missed the fact that the RL was not the same as the TL or the Accord.
Old Jan 1, 2007 | 12:10 PM
ORIGINAL: vintageant
Old Jan 1, 2007 | 12:21 PM
Default RE: Acura RL wheels? UpDate!
Hi Guys***
Here is an up date for you all on the 2006 Acura RL's wheel size.
The stock wheels on this car are 17"x8" with a bolt pattern of
5 lugs on 115mm and by the way the OEM wheels run as high as
$550.00 each and their made by Asahi Mfg company who makes custom wheels also..
[IMG]local://upfiles/22/AE9BEC6692DF4811BCC4360FB63560D3.gif[/IMG]
StrikingAccord
May 15, 2011 03:25 PM
StrikingAccord
Jul 5, 2010 11:41 PM
Kool Kid
Nov 26, 2007 08:55 PM
White03Sedan
Feb 20, 2007 09:10 AM
bbklover
Feb 12, 2006 02:11 PM
