Advice on Wheels Need 03 Accord Type S
Old Nov 11, 2008 | 03:19 PM
vaf888
Default Advice on Wheels Need 03 Accord Type S
Hi All
Hope some can help. Does any recognise these wheels. I am looking to put these onto my 2003 Accord Type S. Simply put they fit.
The wheels have the following markings on the inside
Enkei 5
The Honda Motor Company
17x7jj
55
S3N 77OB
this link shows it on a prelude http://www.pistonheads.com/sales/758322.htm
I need to know the stud pattern and if the offset will fit may car. Does any know what the offset of standard honda five spoke penta wheels are?
Thanks for any help
Old Nov 12, 2008 | 08:40 AM
falkore24's Avatar
Default RE: Advice on Wheels Need 03 Accord Type S
LOL @ Accord Type S!!!!!
Old Nov 12, 2008 | 11:37 AM
finch13's Avatar
LOL @ falkore being a noob!
Dude, he's from Belfast, which is EDM, which means the Accord is the TSX here, which means it is a Type-S, a TSX Type-S.
As for the wheels, they are 17" (432mm) diameter and 7" (178mm) wide with a +55mm offset and a 5x114.3mm lug pattern, they will fit your car perfectly. Also they have a JJ-type rim lip.
I figured all that out from the info you provided. As far as what they were called. I have no clue, the look familiar but not from an Accord...
Old Nov 12, 2008 | 02:30 PM
vaf888
finch13 - thanks for the support and the info. Great help. As for folkore24 know your car's before taking the ****.
Finch are all honda 5xstud all 114.3 throughout the world. How do you know from the info, that the wheels are 5x114.3 the guy that is selling thinks they are 5x100. my main concern was the offset +55 as most site say that the 0ffset is between 45-52. Does +55 cause rubbing on full lock or load.
Notice yours is a typeS, are those DC5 as they are a +55 offset?
Cheers
Old Nov 12, 2008 | 04:00 PM
falkore24's Avatar
ORIGINAL: vaf888
Old Nov 12, 2008 | 04:02 PM
finch13's Avatar
All 5 lug Honda are 5x114.3mm, 4 lugs differ though, Accords and bigger models are 4x114.3mm and Civics and similar sized cars are 4x100mm, including Integras. The only way to know for sure is to have the guy make a 114mm diamter circle on a piece of paper and it should run through the center of each lug.
You will be able to run that offset just fine, they may stick out a tad farther, but you shouldn't rub on anything. 55mm is only 3mm from 52mm... that's not a big difference at all. Even from 45mm, it's only pushing the wheels out 1cm on each side.
I don't understand this...
finch13's Avatar
ORIGINAL: falkore24
ORIGINAL: vaf888
Hahahaha @ both of you.
Old Nov 12, 2008 | 04:07 PM
falkore24's Avatar
couldn't pass it up ..... yeah, geography isn't a strong point of mine.
Old Nov 12, 2008 | 04:14 PM
finch13's Avatar
Clicking on user names and looking at their location doesn't take much effort :P
Old Nov 12, 2008 | 04:17 PM
falkore24's Avatar
But designing some seriously complex ish at the same time is!!!!
