Brake light on after shoe change?
Old Aug 27, 2008 | 04:07 PM
visbits
Default Brake light on after shoe change?
Hey guys, I have a 98 accord and I recently changed the shoes on the rear. I was wondering why the brake light is now lit when the brakes are in fact fully released. The light goes out if push on the brakes hard.
Thanks!
Old Aug 27, 2008 | 08:57 PM
cjdm98's Avatar
Default RE: Brake light on after shoe change?
Could be the early signs of master cylinder wear. Check your fluid.
Old Aug 29, 2008 | 09:21 AM
visbits
Res is full. What else should I check?
Thanks for helping, Tyler.
Old Sep 27, 2008 | 11:54 AM
visbits
bump
Old Sep 29, 2008 | 01:16 AM
[sm=americanasmiley.gif]No bumping in the forums...[&:]
Check brakelight switch...
Old Sep 29, 2008 | 08:02 AM
finch13's Avatar
No bumping??? It's been a month...
How far can you pull up the emergency brake? Have you checked that switch? That will also cause the light to come on.
Old Sep 29, 2008 | 08:45 AM
08coupex's Avatar
You might have to bleed your brakes. Your saying shoes so you have drum brakes correct.
Old Sep 29, 2008 | 04:37 PM
cbarron814's Avatar
yes i agree bleed the brakes
Old Oct 5, 2008 | 10:10 PM
visbits
ORIGINAL: finch13
Handle pulls up nearly all the way and dosnt seem to effect the brakes much.
I bled the system, I don't think there is any air in there. I could bleed it all again but I doubt that's going to help.
Could the auto adjuster's on the drums being to loose? How does the handbrake sensor work.
Thanks!
Old Oct 6, 2008 | 09:11 AM
falkore24's Avatar
To set the auto adjuster, brake hard in reverse about 10 times in a row from about 5 mph.
