help an idiot buy rims for 08 accord sedan lx
Old Sep 10, 2008 | 08:41 PM
oogie
Default help an idiot buy rims for 08 accord sedan lx
So i bought an 08 accord lx with the ugly hubs. I was too broke for the higher end models but wanted an accord so bad.
I love it so far, but need rims bad. I'm a total car idiot and have no idea what rims will fit this car and how to go about figuring out which rims i can use.
Can anyone tell me what i'm looking for and maybe recommend a few rims that would fit this car without having to do major work on it.
Thanks.
2008 honda accord lx sedan
Brushed metal metallic color
4cyl
If you need anymore info than this tell me.
Old Sep 11, 2008 | 07:23 AM
Default RE: help an idiot buy rims for 08 accord sedan lx
Hello New Member:
Welcome to the HAF :
Here are the sizes and bolt patterns that fit your Accord...
The bolt pattern is 5 lugs on 115 mm and the wheels sizes are 16 x 6.5 or 17 x 7.5 or 18 x 8
Hope this helps you out..here's a good looking wheel...
[IMG]local://upfiles/22/D00CB676DE9B4F42AAE4E63462EA1DF0.jpg[/IMG]
Old Sep 15, 2008 | 12:27 AM
oogie
http://www.tirerack.com/wheels/resul...odClar=LX+4cyl
So i checked that website, entered the specs for my car, and got a whole slew of different wheels. Now when i click on them...they show
Bolt pattern: 5-114
Is that ok?
also, alot of them show 18 x 7.5...or 18 x 8.5. Would these not work? Do i need 18 x 8 exactly?
And what does the offset and backspacing mean? Is that mainly for tire sizing?
Thanks for the first reply tho.
Old Sep 16, 2008 | 11:00 PM
xxh0tsaucexx's Avatar
I'm here to learn aswell so please fire away Mr. Administrator.
Old Sep 17, 2008 | 07:43 AM
Okay Guys..do this for yourselfs..Look up top of this post where it says Tires and Wheels and click on it ...then read my post in that fact section...then let me know if that helped you!
[IMG]local://upfiles/22/2F1CED1540E244B2B68E98C25C44237E.jpg[/IMG]
Old Sep 17, 2008 | 08:09 AM
falkore24's Avatar
that rsracing link is pretty cool .... first time I looked through it!!!
Oogie is correct with 114mm though .... or 4.5"
Old Sep 17, 2008 | 10:00 PM
oogie
wow so that site is cool, but i think it just blew my mind and made me even more confused. Too much terminology for buying rims. :P
So lemme just ask this and i'll shut up.
So the 114mm thing is ok it seems.
Is 18x8.5 ok as well? or do i specifically need the 18x8?
Thanks.
Old Sep 18, 2008 | 10:08 AM
falkore24's Avatar
The 8.5 is the width of the rim .... the offset determines if it will rub or not .... width does a little, but I wouldn't expect 8.5 to be an issue if the offset is right. There are charts that tell you what the recommended tire widths are for different rim widths.
BTW - it is actually 114.3mm bolt pattern, which is exactly 4.5".
Old Nov 5, 2008 | 11:00 AM
sober1's Avatar
ORIGINAL: WheelBrokerAng
Hello New Member:
dang, i really like that rim...a nd it would look tight on my black 04 sedan... what kind is it?
thansk
Old Nov 5, 2008 | 11:31 AM
falkore24's Avatar
to the OP: Please take a look at the tools and calculator links in the Tires and rims sticky. They might clarify some of the fitment concerns for you.
