lock nuts
Old Nov 25, 2008 | 07:09 PM
bevelman
Default lock nuts
Hi guys i lost the key, to remove the lock nuts on my accord 2005.I phone the company who supply the lock nut ,they say at least 2 weeks waiting time. Is there a way to remove the lock w/o damage the mags what are my other options?tank you
Old Nov 25, 2008 | 07:14 PM
Tippman7641's Avatar
Default RE: lock nuts
if u can get me a pic of the lock it self on the wheel i can tell you where and how to get one
Old Nov 25, 2008 | 07:26 PM
bevelman
ok my cars is a honda accord 2005 v6 6 speed i need to install my winter tires the company is Mcgard .Do you need a pics?
Old Nov 25, 2008 | 08:25 PM
just of the wheel lock it self to see the kind, im almost sure of what its gonna be but i gotta make sure
Old Nov 25, 2008 | 09:58 PM
bevelman
ok i have to go to bed am working night, i will get you a pics after work .
Old Nov 25, 2008 | 10:11 PM
accordin2u's Avatar
Here's something you could try. You could get either a 3/4 or 13/16socket which ever one is the tightest and pound it on the lock itself and then turn the lock off using a rachet or breaker bar. You could then replace it with a regular lugnut or wait until your new key arrives. The socket has to be 12 point.
Old Nov 25, 2008 | 10:15 PM
there are specail kits for that, and they are complelety rounded on the inside
Old Nov 26, 2008 | 09:56 AM
falkore24's Avatar
Lost key, locking lug removal tool is an impact socket with a reverse thread in it. It tightens as the lock is removed and you will have to grind flat sides to get the socket off of the lock, rendering the lock useless.
Old Nov 26, 2008 | 11:33 AM
accordin2u's Avatar
ORIGINAL: accordin2u
When I've done this the lock is still usable. You just lay the socket flat with the lock inside it and hit it with a hammer and it will pop out. You should be able to use the socket four times , but the socket probably will be ruined after you're finished. It really all depends on how tight the lock was really put on at first(impact or torque wrench).
Old Nov 26, 2008 | 11:47 AM
i can probly get youu a key for mabe 10$ at most, and yesh there are removal sets that remove the locks WITHOUT damaging them, i work at a tire store,
