lug conversion
Old Nov 2, 2008 | 10:08 PM
TRUCHA
Default lug conversion
so i have a 96 accord and it has 4 lug wheels and i want to get a lug conversion like at least 5 lug wheels cuzz thatz wut most rims come with wut do u recommend
Old Nov 2, 2008 | 10:22 PM
Default RE: lug conversion
at least 5 lug? what do you want 6 lug truck hubs? lol. I've seen people swap prelude hubs over before, alot of work involved though.
Old Nov 2, 2008 | 10:35 PM
cjdm98's Avatar
Keep the 4 lug hub, and get a rear disc conversion,less work, 4 lug wheels are easy to find and cheaper in most cases.
Old Nov 4, 2008 | 12:07 AM
TRUCHA
no dudes not hug caps lug nuts
Old Nov 4, 2008 | 07:04 AM
falkore24's Avatar
Old Nov 4, 2008 | 09:59 AM
Yes anyways like I was saying, I was not referring to hub caps. You would need the front knuckle assembly of a odyssey(can be done with prelude but requires more custom fab because the prelude uses a bigger ball joint).
They will need calipers/brackets from any of the following:
94-97 accord wagon, 92-96 prelude dohc vtec, 97-01 prelude, 92-95 legend gs, 97-01 integra type-R
and rotors from any of the following:
97-01 prelude base model, 95-98 odysessy, 97-01 integra type-R, 94-97 accord wagon
That is the front, for the rear you will need the hub and bearing set up from a 97-01 prelude.
You will then be able to run these rotors:
98-02 accord v6 coupe or sedan (note: it must be a v6 model)
Old Nov 5, 2008 | 08:46 PM
TRUCHA
wow dude tanx 4 the info that really helps but it sounds expensive do u have an estimate on how much it would cost
Old Nov 5, 2008 | 09:06 PM
its not all too expensive, you can get the front knuckles for the odyssey for about $50-100 a piece.
Not all too sure on the rear hub assembly, about the same price, a little less.
then just reg rotor and caliper prices.
Old Nov 6, 2008 | 08:24 AM
accordin2u's Avatar
Why not just get adapters? They sell them for 4 lug to 5 lug conversions for about $150.00
Old Nov 6, 2008 | 10:32 AM
finch13's Avatar
Because they suck. Period. If you want to the swap, do it correctly. It's worth shelling out 5 bills to do.
