pick my rims
Old Sep 13, 2007 | 03:38 PM
y9pema's Avatar
Default RE: pick my rims
i think the rota's for the win!! thanks all for your input.
Old Sep 27, 2007 | 01:22 PM
01/V6/ACCORD/AT
hey guys well i need a bit of help i wuz wondering it you guys could help me out on this one im trying to put some rims on my car 20" and i need to get the right off set so they dont rub when i turn and still keep the stock turning radious and i was wondering if any one had the specs or something im trying to go as big as i can on the rims sizes but still keeping the the sameturning radious?
2001 Honda Accord Ex V6 4-Door
AEM-V2
Magnaflow Cat-Back
DC Headers
Eibach-Sporline Lowering Kit
and F&R Sway Bars
Old Sep 27, 2007 | 01:28 PM
sir_nasty's Avatar
First off I would probably suggest starting a new thread for this question so you'd get more answers but none the less. Your offset should be at minimum about +40 or +45 the higher offset you go the more the rim moves out and this allows you to get wider tires, to high of an offset and to wide of a tire and they will stick out. I can't recall for certian (there was some discussion about this last week) but I believe on a 2000 accord if you went with a +45mm offset and a 60 series 20 inch tire that will bring the rim and tire nearly flush with the outside of the fender well. Much bigger than that or a higher offset and they are going to stick out. Just confirm this with whoever you order the tires/rims from and they should know as well.
Old Sep 27, 2007 | 01:36 PM
01/V6/ACCORD/AT
my bad i also forgot im trying to go and run the 20"s with a 30 or 35 series tire?
AEM-V2
Magnaflow Cat-Back
DC Headers
and F&R Sway Bars
Old Sep 27, 2007 | 02:10 PM
sir_nasty's Avatar
how about a 225/30R20? That throws off your speedo by about 1.45% but gives you an additional 2-3 inches width. Then just decide what you want for an offset. You need a 7.5-9 inch wide rim for that tire.
Stock Tire - 205/60R16 >Search Tires Tire 1 - 225/30R20 >Search Tires Section Width:8.07 in205 mmSection Width:8.85 in225 mmRim Diameter:16 in406.4 mmRim Diameter:20 in508 mmRim Width Range:5.5 - 7.5 inRim Width Range:7.5 - 9 inOverall Diameter:25.68 in652.27 mmOverall Diameter:25.31 in642.87 mmSidewall Height:4.84 in122.93 mmSidewall Height:2.65 in67.31 mmRadius:12.84 in326.13 mmRadius:12.65 in321.31 mmCircumference:80.67 in2049.0 mmCircumference:79.51 in2019.5 mmRevs per Mile:809.9Revs per Mile:821.8Actual Speed:60 mph100 km/hSpeedometer1:60.8 mph101. km/hSpeedometer Difference: -Speedometer Difference: 1.469% too fastDiameter Difference: -Diameter Difference: 1.45%
North East
Mar 22, 2014 03:33 PM
falkore24
Nov 13, 2008 08:52 AM
Sig86 CM8
Oct 14, 2008 09:29 PM
academic
Jan 19, 2008 04:43 PM
elvis0029
Oct 23, 2005 10:10 PM
