Stock alloys for my '05 sedan lx 4cyl....
Old Sep 6, 2005 | 10:38 PM
B8mn1
Default Stock alloys for my '05 sedan lx 4cyl....
I am interested in some of the newer style 5 spoke stock alloys for my new accord.... will the 16" bolt on?? are there any larger "Honda" wheels??
Any recommendations for cool, inexpensive (less expensive) wheels / tires.. I was hoping to locate so new take-offs someone wants to dump....
Thanks, Ben
Old Sep 8, 2005 | 04:35 AM
Default RE: Stock alloys for my '05 sedan lx 4cyl....
Hi New Member...
My question to you is this...you have a new 2005 Accord LX 4dr and you are looking for newer Alloy Honda Wheels 5 spoke...is this correct?
Maybe Like These?
[IMG]local://upfiles/22/744D9A968C974C93BE52CCE49ADBA84A.gif[/IMG]
Old Sep 8, 2005 | 05:32 AM
B8mn1
My LX came with steel wheels and hub caps...
I would like to find some alloy wheels reasonable,,, I thought if someone had bought a new car and removed the wheels for 18" or so, maybe they would be interested in selling the stock alloys for a reasonable price....
Tha photo you posted is what I like.....
Got any?? are they cheap?
Thanks,
Ben
Old Sep 17, 2005 | 12:45 AM
B8mn1
Okay, I don't know if anyone is still looking at this thread, but......
I just found an ad for '05 acura TL 17" factory Alloy wheels and michelin pilot 235/45/17 tires,, less than 2k mikes, for $600.00... Does anyone know how they will fit my '05 accord lx ...... will they be too wide??? they are obviously 30mm wider than stock, but I'm not sure the offset... if they would stick out I'll pass,,,,
opinions???
Wheelbroker.. your thoughts??
Thanks,
Ben
Old Sep 21, 2005 | 01:11 AM
Hi sorry about the delay but I forgot about this thread...but here I am again..
The wheels from the 05" Acura TL and the 05 Accord are interchangeable , they are both the same bolt pattern and will fit both cars...
Here are two pictures of those wheels for you to check out...
Hope this is good for you....
[IMG]local://upfiles/22/750C120F5EA04C0B90E8B02C23073435.gif[/IMG]
[IMG]local://upfiles/22/C8BE46277DEA4C71A0EF60A75E7314D3.gif[/IMG]
Old Sep 21, 2005 | 02:44 AM
B8mn1
WheelBrokerAng,
I am really concerned about the tires fitting under the wheel wells... 235/45/17's are pretty wide, and it almost looks like the front fenders on an Acura are flaired more then the accord...if so, that would cause them to stick out....?? have any experience with this size wheel / tire on an accord???
Thanks for all you input...
Ben
Old Jun 28, 2006 | 01:02 AM
mamarotta's Avatar
well hello all I have the same question... i am abou tot put on the same wheel on my 05 accord 4 cyl but i have ordered 245 45 17 tires. Ill post after I try this...to late but i couldnt wait anylonger so i went ahead to try it. if it doesnt work i have a prefectly good set of brand new wheels an tires...let u know soone enough.
Old Jun 29, 2006 | 02:23 AM
They will not fit your accord...the tires that is..the 235mm tires do fit the TL..
your 05' Accord takes a 215/50/17 tire which fits in there the correct way...
ORIGINAL: B8mn1
opinions???
Thanks,
Ben
Old Jun 29, 2006 | 02:50 AM
mamarotta's Avatar
well accord to where i bought my wheels they fit the tl and accord...so then if that fits both then there is a possiblity that the 245 45 17 might fit if its a little wider
Old Jul 4, 2006 | 10:43 AM
mamarotta's Avatar
tl wheels fit with slight rubbing on bumpy roads other wise just fine and look great....center caps next.
