tire pressure monitor sensors
Old Mar 21, 2008 | 05:47 PM
oneslowaccord's Avatar
Default tire pressure monitor sensors
i have a 2008 honda and if i remove the stock wheels will the sensor light on the dask stay on all the time or will it turn off after awhile thanks....
Old Mar 21, 2008 | 05:55 PM
gomarlins3's Avatar
Default RE: tire pressure monitor sensors
I believe it will stay on the entire time, but I do not know that for sure. You could call your service department at the dealer where you got your car.
Old Mar 21, 2008 | 09:24 PM
thanks for the reply.i found the anwser for my question any ways it will stay on.
Old Mar 23, 2008 | 08:19 PM
gomarlins3's Avatar
What was the final conclusion?
Old Mar 23, 2008 | 09:23 PM
finch13's Avatar
Probably a good idea if you buy wheels to have the sensors transferred to the new wheels. Not cheap, but the TPMS is picky.
Old Mar 24, 2008 | 02:10 PM
$ini$ta's Avatar
damn so i guess im gonna have that problem with mine then...does it have to be the dealer to fix that or can the tire place do it?
Old Mar 29, 2008 | 12:23 AM
loki's Avatar
When I put my wheels on two weeks ago Discount Tire charged me $20.00 for a tmps rebuilding kit , that was for all 4 wheels. not bad considering the price of chrome wheels.
Old Apr 4, 2008 | 06:19 PM
james_and7's Avatar
I just got back from the shop and found out that they need to get the codes of the sensors off the tires to input them into the system. I have an 08 accord coupe EX which came with 17's, I removed them and put on factory 18's from the V6 version and now I have that TPMS light that won't go away. My function to disengage the VSA is no longer available as well. I'll keep you posted on the progress.
I'm wondering if I should just get the sensors from my factory tires and put them in these ones...but It'll probably cost the same in labour (which they quoted me at 110). The dealer wanted to run a diagnostic for of $70 before they say anything. Any suggestions?
Old Apr 4, 2008 | 06:21 PM
sir_nasty's Avatar
Certain shops are now getting certified to transfer/work on tires that have those sensors, find a shop that holds the certification and usually they will guarantee their work.
Old Apr 4, 2008 | 08:13 PM
falkore24's Avatar
Hey SN .... no chance that resetting the computer would work? I know that my tC has a reset button and if you reset it with no signal, there's no light. Also, the whole system seems kinda stupid to me ... it would make sense if it let you know of 4-5 lbs missing, but "critically low"??? Wouldn't the steering wheel tell you first?
