Would 215/65r16 tires fit stock OEM Honda Accord rims?
The tires will fit on the rims but they will be both wider and taller than the stock tire size; said another way, you may experience rubbing/tire damage on bumpy roads or when you have the steering wheel turned full-lock. The other issue is your speedometer and odometer will under report your speed and distance traveled.
