Would 215/65r16 tires fit stock OEM Honda Accord rims?
Old Oct 20, 2010 | 11:09 PM
Andrew James's Avatar
Default Would 215/65r16 tires fit stock OEM Honda Accord rims?
Currently running 205/60R16s, any issues in running 215/65R16 tires?
2000 Honda Accord, 16inch stock OEM rims.
Thanks.
Old Oct 21, 2010 | 11:55 PM
No replies?
Old Oct 22, 2010 | 02:06 AM
Those will fit the stock rims...
Old Oct 23, 2010 | 03:13 PM
I didn't think it would be a problem, just making sure there would be no issues.
Old Oct 24, 2010 | 08:05 AM
g22cd5's Avatar
Supper Moderator
are you lowered?..might have rub issue if your fenders aren’t rolled.
Old Oct 24, 2010 | 02:56 PM
Okay then...
Happy Football Sunday!
Old Oct 25, 2010 | 08:51 PM
Thanks guys!
Stock Accord, no aftermarket whatsoever.
Old Nov 5, 2019 | 10:14 AM
Jacob D's Avatar
Default Did they fit?
Hey Andrew did you ever go through with putting these on? I have a set of 215 65 16 sitting around hoping they will fit
Old Nov 5, 2019 | 12:37 PM
shipo's Avatar
The tires will fit on the rims but they will be both wider and taller than the stock tire size; said another way, you may experience rubbing/tire damage on bumpy roads or when you have the steering wheel turned full-lock. The other issue is your speedometer and odometer will under report your speed and distance traveled.
Old Jun 5, 2020 | 05:41 PM
Kenneth Pino's Avatar
Default 215/65/16 tires on OEM wheels. Accord 2012
They fit and will give no issues. I have them fitted on OEM Honda wheels and the car performs flawlessly. Have not checked for speedometer accuracy.
