'99 front door speaker adapters
I'm contemplating replacing the factory stereo with an aftermarket (HD Radio, iPod interface, etc) and have (2) pairs of older Infinity Kappas that I'd like to re-use. They're 5-1/4" though.... I can get adapters for the rear deck from Crutchfield but they don't officially offer anything for the front doors.
Short of making adapters (out of wood), has anyone done this ? That is, put 5-1/4" speakers in place of 6-1/2"s ? If so, what did you use ?
If you made them out of wood, how thick can you go and maintain the factory grille ?
I used 3/4 mdf to make my baffels (03) and maintained factory grills. trace the outside of the stock baffle. then cut the inner circle out to make it fit the 5.25 and your set.
my build log (link in sig) and the door speaker sticky both show the door baffle process in detail. yes, 3/4" is fine and gives you more depth. the factory speaker is an odd size anyway and nothing aftermarket is equal. so 5-1/4" are fine.
2010HondaAccordLiquidMetal
04-22-2014 11:41 AM
ProAutoGlassllc
05-21-2013 12:45 AM
cyberdork
09-25-2008 05:24 PM
