2006 Accord sedan SQ Audio build
Old 08-27-2013, 07:10 PM
audioman79's Avatar
Default 2006 Accord sedan SQ Audio build
This is a sound quality build I did for a friend that owns a 2006 honda accord sedan.
sedan. The goal of the system will be a stealth build where everything in the trunk will be out of sight.
Goals of build:
-Provide Great sound quality while sticking to budget
-stealthy trunk build and leave as much space possible for daily
use
The list of products
Pioneer DEH-80prs Headunit
Mosconi 6to8 DSP
Mosconi Gladen one 120.4 amp
Mosconi Gladen one 240.2 amp
Image Dynamics IDQ10D2 V.3 10" subwoofer
Illusion Audio Carbon C6 6.5" components
The pioneer 80prs was installed using Bestkits install in lower storage pocket.
next moving onto the doors, removing the panels and treating sheet metal
with focal Bam XXXL and Blackhole tile.
Old 08-27-2013, 07:18 PM
audioman79's Avatar
Next adapters
where made from 3/4" mdf for the front doors to mount the illusion audio c6 mids. Then adapters were sprayed with bed liner.
Old 08-27-2013, 07:19 PM
audioman79's Avatar
Old 08-27-2013, 07:20 PM
audioman79's Avatar
Old 08-27-2013, 07:23 PM
audioman79's Avatar
Next the tweeters were installed in factory location to have a stock appearance
Old 08-27-2013, 07:28 PM
audioman79's Avatar
Moving on to the rear doors, they received the same treatment as the front doors
Old 08-29-2013, 09:27 AM
audioman79's Avatar
I ran 1/0 gauge power wire to power the system on the driver side and ran the signal wires down the passenger side.
.Name:  20130728_220158_zpscce5e976.jpg
Old 08-29-2013, 09:30 AM
audioman79's Avatar
Moving onto the trunk, a 3/4" mdf base was mounted to the spare tire area to house the amp rack and a sealed .75 cu.ft enclosure. screw rivets were used to secure the base to the car.
Old 08-29-2013, 09:34 AM
audioman79's Avatar
Next the trim panels are cut, routed and sanded.
Old 08-29-2013, 09:36 AM
audioman79's Avatar
The trim ring that hide the sub woofers screw mounts in place using neo magnets
Quick Reply: 2006 Accord sedan SQ Audio build
