Accord 2002 Timing Chain?
Hi, I just bought a 2002 Accord and the salesman told me from 2002 and up they no longer use a timing belt which had to be changed at every 100 000 KM. They now use a timing chain.The chain will last the life of the car, is this true?I think I might have been lied to. My research has shown me so far that the 2003 uses a timing chain.
It's a 4 cylinder, 2.3 liter. Any answers would be appreciated.
RE: Accord 2002 Timing Chain?
4cyl is a timing chain, V6 is a belt, here's the wikianswer for it as well
http://wiki.answers.com/Q/Does_a_200..._a_timing_belt
Check the owner's manual under 105,000 mi (170,000 km) maintenance. It should say to change the timing belt, but I have the V6. I think they're both belts as mentioned above.
https://www.hondaaccordforum.com/Whe...m_51051/tm.htm
you guys are correct Accords uo to 2002 4 cyl still had a belt,, 2003 on, ..timing chain
NoORs
04-04-2015 01:54 PM
harrishonda
10-03-2010 03:59 PM
