Accord 2002 Timing Chain?
Old Sep 25, 2007 | 05:23 PM
kosta
Default Accord 2002 Timing Chain?
Hi, I just bought a 2002 Accord and the salesman told me from 2002 and up they no longer use a timing belt which had to be changed at every 100 000 KM. They now use a timing chain.The chain will last the life of the car, is this true?I think I might have been lied to. My research has shown me so far that the 2003 uses a timing chain.
It's a 4 cylinder, 2.3 liter. Any answers would be appreciated.
Old Sep 25, 2007 | 05:30 PM
sir_nasty's Avatar
Default RE: Accord 2002 Timing Chain?
4cyl is a timing chain, V6 is a belt, here's the wikianswer for it as well
http://wiki.answers.com/Q/Does_a_200..._a_timing_belt
Old Sep 25, 2007 | 06:36 PM
stevent's Avatar
^ thats for the 7th gen not 6th gen. The 6th gen (98-02) have timing belts, so the dealer lied to you.
Old Sep 25, 2007 | 07:05 PM
falkore24's Avatar
Check the owner's manual under 105,000 mi (170,000 km) maintenance. It should say to change the timing belt, but I have the V6. I think they're both belts as mentioned above.
Old Sep 25, 2007 | 07:43 PM
NO... It's 2003 & up 4-cylinder 2.4 liter (K-series engine). Your 2002 does have a belt.
Old Sep 26, 2007 | 08:43 AM
kosta
Thanks for the info guys.
Old Sep 26, 2007 | 12:12 PM
smaglik's Avatar
i thought it was usually 90k on a t-belt.
Old Sep 26, 2007 | 03:21 PM
deserthonda's Avatar
https://www.hondaaccordforum.com/Whe...m_51051/tm.htm
you guys are correct Accords uo to 2002 4 cyl still had a belt,, 2003 on, ..timing chain
Old Sep 26, 2007 | 03:37 PM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: smaglik
90k till 1998, then it changed to 105k for the 1998 & newer models
deerdawg
Apr 27, 2013 08:35 AM
ss485
Feb 23, 2011 08:18 PM
harrishonda
Oct 3, 2010 03:59 PM
tracemiller
Jun 24, 2008 01:33 PM
