Could it be fuel pump?
Old 07-21-2008, 12:19 AM
FlyLow's Avatar
Default Could it be fuel pump?
Was changing distributor cap and rotor, after finished went to check if it would start, it did fora few seconds but then rpm's fell below 500 and it died. It wouldn't start since. I can't hear the fuel pump as I turn on the ignition, as I always did.How can I check the fuel pump with a multi-meter without taking it out of the tank. I tried checking voltage in the connector that attaches to fuel pump, got readingsin of2 pins out of total of5. But I don't have the pin out, I don't know what those pins are. Any help would be great.
Old 07-21-2008, 12:21 AM
FlyLow's Avatar
Default RE: Could it be fuel pump?
the car above is 2dr 99 Accord VTEC LX 5-spd
Old 07-21-2008, 06:13 PM
logan's Avatar
hmmm your rotor might not be on there properly
rockhoundrob
04-11-2014 11:41 AM
Westjoe64
10-15-2012 12:11 PM
kissbally78
01-18-2009 07:14 PM
boots
03-17-2006 06:01 PM
driver93
12-19-2005 05:22 PM
Quick Reply: Could it be fuel pump?
