Slave/Master Cylinder location
Old 06-16-2011, 10:37 AM
tradosaurus's Avatar
Default Slave/Master Cylinder location
I have a 2001 Honda Accord EX 2.3L.
Can someone post a diagram/picture showing the location of both clutch cylinders?
I'm having a hard time shifting into first either from 2nd or from neutral and need to check for leaks.
Gracias!
Old 06-16-2011, 05:48 PM
Sorry no pic's of a 6th gen.....anyway there should be a small res, near, just around the brake master cyl.
The slave should be towards the front of the car about where the trans and engine meet....should be mounted to the trans.
Old 06-19-2011, 09:23 PM
Clutch master cylinder is on the firewall, far left. The clutch fluid reservoir is visible (#12 in the picture), so follow the hose down under the overhanging cowling.
The slave cylinder (#5) is bolted to the engine, sorta mid-elevation, alongside the lower part of the exhaust manifold. Look down between the engine & the radiator.
Old 06-23-2011, 07:07 AM
Thank you.
Leoniel1245
04-25-2015 09:50 AM
sparkleegrl
06-27-2012 02:03 PM
magowie
05-13-2010 06:03 AM
gonecrazy
10-12-2005 11:57 PM
gonecrazy
10-12-2005 11:57 PM
Quick Reply: Slave/Master Cylinder location
