Sponsored by:
Sponsored by:
88 honda accord noises
Old 04-30-2009, 07:10 PM
alpinestars06
Default 88 honda accord noises
I have an 88 honda accord. Just replaced the passenger side strut. It was worn. The car makes a loud squeek when you turn the wheel or take off from a stop. You can hear it when you bounce the car. Alot louder on take off and turning. I checked the ball joints and wheel bearing. No movement or play. I was told it could be the in board side of the cv axle. Any other suggestions?? Thanks
Old 05-01-2009, 08:00 AM
Seems to me that's more likely a squeaky suspension bushing. Don't forget to check the anti-roll bar bushings.
Old 05-01-2009, 03:18 PM
deserthonda's Avatar
was the noise there before you replaced the strut ??
if not chk the work just done
if yes do as Jim suggested chk the sway bar bushings, also chk the radius rod bushings and make sure that the nut is tight
Akatzman
09-29-2013 02:37 AM
letsclique
02-29-2012 12:30 PM
derekcentrico
11-22-2009 11:49 PM
SunImNw
10-16-2008 08:14 AM
ranst20
04-06-2006 02:17 AM
Quick Reply: 88 honda accord noises
