05 accord radio help
My radio went out and it's a single climate control would I be able to replace with a dual climate control radio I don't care about the dual control just my radio to work with just one green plug clip is it possible ??
( Dual control has 2 green clips )
Thanks
Thanks
I don't know if the replacement unit will work. The best advise is to either find an identical replacement, or have your current radio repaired.
I thought the cd/radio was separate from the climate control. You should look up the OEM part number for your current radio and the replacement to see if they have the same part number. You may be able to swap the replacement radio into your current climate control.
djaycardona
11-26-2013 04:07 PM
GMANCRX
07-15-2013 02:50 PM
