05 accord radio help
Old Mar 14, 2017 | 04:41 AM
Denny Lao's Avatar
Default 05 accord radio help
My radio went out and it's a single climate control would I be able to replace with a dual climate control radio I don't care about the dual control just my radio to work with just one green plug clip is it possible ??
( Dual control has 2 green clips )
Thanks
Old Mar 18, 2017 | 05:15 PM
I don't know if the replacement unit will work. The best advise is to either find an identical replacement, or have your current radio repaired.
I thought the cd/radio was separate from the climate control. You should look up the OEM part number for your current radio and the replacement to see if they have the same part number. You may be able to swap the replacement radio into your current climate control.
djaycardona
Nov 26, 2013 04:07 PM
GMANCRX
Jul 15, 2013 02:50 PM
mamtsberg
Mar 17, 2010 09:15 PM
RecMK5
Feb 13, 2009 06:33 AM
shirl1269
Jan 17, 2006 02:24 AM
