Sponsored by:
Sponsored by:
1999 Honda Accord Clutch/Master/Slave Cylinder Problem
Old 06-27-2012, 12:06 PM
sparkleegrl's Avatar
Default 1999 Honda Accord Clutch/Master/Slave Cylinder Problem
I have a 1999 honda accord. When I am driving and then at a stop with the clutch depressed for a while if I try to put it in first gear it will not go. Then I check all gears and it will not go into any gear. I then let off the clutch when I depress the clutch again it goes straight to the floor. I turn my car off and then on again then the clutch appears to be fine and I can put it in first gear and drive. What kind of problem do you think this is? Someone told me it might be my slave cylinder? I need to take it to a shop but I want to make sure I don't get ripped off, thanks.
Old 06-27-2012, 12:17 PM
Dr. Drivability's Avatar
sounds like a bad slave cylinder, probably bypassing by what you described is happening. just keep a shop from replacing the clutch first, make sure they properly diagnose the system
Old 06-27-2012, 01:48 PM
Default Thanks
I'm taking it to a shop tomorrow afternoon. Thanks for the info.
-Lisa
Old 06-27-2012, 02:03 PM
let us know what happens.
Leoniel1245
04-25-2015 09:50 AM
tradosaurus
06-23-2011 07:07 AM
magowie
05-13-2010 06:03 AM
gonecrazy
10-12-2005 11:57 PM
gonecrazy
10-12-2005 11:57 PM
Quick Reply: 1999 Honda Accord Clutch/Master/Slave Cylinder Problem
