Sponsored by:
Sponsored by:
2005 accord v6- mes plug to reset srs light ?
Old 01-28-2010, 12:12 PM
jtnixit's Avatar
Default 2005 accord v6- mes plug to reset srs light ?
i have an 2005 accord v6.. can someone please tell me exactly where the yellow plug is so i can reset the srs light... i think i found it but the only problem is there is 2 yellow plugs.. one is small and the other one is larger..also i tried to pull the plug out and it doesnt wanna come out.. does it just pull out or is there a clip on it.. im affraid to pull on it real hard or wiggle it and break it
Old 01-28-2010, 03:47 PM
jtnixit's Avatar
hello.... anyone ????
Old 01-28-2010, 04:23 PM
I'm not sure if there is one on an 05 or where that plug would be.
Make sure that you have the correct plug. It should be plugged into a plastic plug that has no wires leading to it. If you are not sure, then don't mess with it.
On my 95 looking from the driver's seat, it is on the driver's side on the left. It was very close to where the plastic knee bolster meets the left panel. Your 05 may be completely different.
Old 01-30-2010, 08:27 PM
i just took my 02 to the dealership because of the srs light and it was a bad module that was covered under warranty... i'm sure yours is too
Hondalover
03-05-2011 09:57 AM
renegade05
08-10-2010 10:43 PM
wish234
03-15-2009 03:32 PM
JeffB
06-29-2008 08:16 PM
Busareds
06-26-2007 05:50 PM
Quick Reply: 2005 accord v6- mes plug to reset srs light ?
