2005 accord v6- mes plug to reset srs light ?
i have an 2005 accord v6.. can someone please tell me exactly where the yellow plug is so i can reset the srs light... i think i found it but the only problem is there is 2 yellow plugs.. one is small and the other one is larger..also i tried to pull the plug out and it doesnt wanna come out.. does it just pull out or is there a clip on it.. im affraid to pull on it real hard or wiggle it and break it
I'm not sure if there is one on an 05 or where that plug would be.
Make sure that you have the correct plug. It should be plugged into a plastic plug that has no wires leading to it. If you are not sure, then don't mess with it.
On my 95 looking from the driver's seat, it is on the driver's side on the left. It was very close to where the plastic knee bolster meets the left panel. Your 05 may be completely different.
